Quick reference for the Renesas RA
Renesas Evaluation Kit for RA6M2 MCU Group
machine.freq()    # get the current frequency of the CPU
Following functions are not supported at the present::
p0 = Pin('P000', Pin.OUT)      # create output pin on P000
p0.on()                        # set pin to "on" (high) level
p0.off()                       # set pin to "off" (low) level
p0.value(1)                    # set pin to on/high
print(p2.value())              # get value, 0 or 1
p4 = Pin('P004', Pin.PULL_UP)      # enable internal pull-up register
The following drive keyword argument are available if the port drive capability of the Pin is supported by the MCU:
Pin.DRIVE_0: Low drive
Pin.DRIVE_1: Middle drive
Pin.DRIVE_2: Middle drive for I2C Fast-mode
Pin.DRIVE_3: High drive
The alt keyword argument is not supported.
The following functions are not supported:
Pin.irq(priority=)  # priority keyword argument is not supported
Pin.irq(wake=)      # wake keyword argument is not supported
Pin.irq(hard=)      # hard keyword argument is ignored because hardware interrupt is used
Pin.mode()
Pin.pull()
Pin.drive()
uart1.write('hello')    # write 5 bytes
uart1.read(5)           # read up to 5 bytes
EK-RA4M1
UART0(REPL)
UART1
UART2
tx
P411
P401
P302
rx
P410
P402
P301
EK-RA4W1
UART1
UART4(REPL)
UART9
tx
P213
P204
P109
rx
P212
P206
P110
EK-RA6M1
UART0(REPL)
UART2
UART8
tx
P411
P302
P105
rx
P410
P301
P104
EK-RA6M2
UART0(REPL)
UART7
UART9
tx
P411
P401
P602
rx
P410
P402
P601
RA4M1-CLICKER
UART0
UART1(REPL)
tx
P411
P401
rx
P410
P402
UART.init(baudrate)   # now only 115200 is confirmed
UART.init(cts, rts)   # Pins are fixed.
UART.init(tx,rx)      # Pins are fixed.
adc = ADC('P000')    # create an ADC object acting on a pin
adc.read_u16()       # read a raw analog value in the range 0-65535
SPI bus
EK-RA4M1
SPI0
sck
P102
mosi
P101
miso
P100
cs
P206
EK-RA4W1
SPI0
sck
P102
mosi
P101
miso
P100
cs
P103
EK-RA6M1
SPI0
sck
P102
mosi
P101
miso
P100
cs
P103
EK-RA6M2
SPI0
SPI1
sck
P102
P702
mosi
P101
P701
miso
P100
P700
cs
P103
P703
RA4M1-CLICKER
SPI0
sck
P102
mosi
P101
miso
P100
cs
P103
SPI.init(firstbit)    # now fixed with SPI.LSB
SPI.init(baudrate)    # now confirmed only 500000
I2C bus
i2c.scan()         # returns list of slave addresses
i2c.readfrom_mem(0x50, 0x10, 2, addrsize=16)  # read 2 bytes from slave 0x50, slave memory 0x10
EK-RA4M1
scl
not supported
sda
not supported
EK-RA4W1
I2C0
scl
P204
sda
P407
EK-RA6M1
I2C0
scl
P400
sda
P401
EK-RA6M2
I2C2
scl
P512
sda
P511
RA4M1-CLICKER
I2C1
scl
P205
sda
P206
I2C.init(freq)    # now confirmed only 400000
SDCard
import os, vfs, sdcard
vfs.mount(sd, '/sd')
vfs.umount('/sd')
