This is the v1.23.0 version of the MicroPython documentation. The latest development version of this page may be more current.
Quick reference for the Renesas RA
Renesas Evaluation Kit for RA6M2 MCU Group
machine.freq()    # get the current frequency of the CPU
Following functions are not supported at the present::
p0 = Pin('P000', Pin.OUT)      # create output pin on P000
p0.on()                        # set pin to "on" (high) level
p0.off()                       # set pin to "off" (low) level
p0.value(1)                    # set pin to on/high
print(p2.value())              # get value, 0 or 1
p4 = Pin('P004', Pin.PULL_UP)      # enable internal pull-up register
The following drive keyword argument are available if the port drive capability of the Pin is supported by the MCU:
Pin.DRIVE_0: Low drive
Pin.DRIVE_1: Middle drive
Pin.DRIVE_2: Middle drive for I2C Fast-mode
Pin.DRIVE_3: High drive
The alt keyword argument is not supported.
The following functions are not supported:
Pin.irq(priority=)  # priority keyword argument is not supported
Pin.irq(wake=)      # wake keyword argument is not supported
Pin.irq(hard=)      # hard keyword argument is ignored because hardware interrupt is used
Pin.mode()
Pin.pull()
Pin.drive()
uart1.write('hello')    # write 5 bytes
uart1.read(5)           # read up to 5 bytes
EK-RA4M1
UART0(REPL)
UART1
UART2
tx
P411
P401
P302
rx
P410
P402
P301
EK-RA4W1
UART1
UART4(REPL)
UART9
tx
P213
P204
P109
rx
P212
P206
P110
EK-RA6M1
UART0(REPL)
UART2
UART8
tx
P411
P302
P105
rx
P410
P301
P104
EK-RA6M2
UART0(REPL)
UART7
UART9
tx
P411
P401
P602
rx
P410
P402
P601
RA4M1-CLICKER
UART0
UART1(REPL)
tx
P411
P401
rx
P410
P402
UART.init(baudrate)   # now only 115200 is confirmed
UART.init(cts, rts)   # Pins are fixed.
UART.init(tx,rx)      # Pins are fixed.
                                             # time, eg 2017/8/23 1:12:48
adc = ADC('P000')    # create an ADC object acting on a pin
adc.read_u16()       # read a raw analog value in the range 0-65535
SPI bus
EK-RA4M1
SPI0
sck
P102
mosi
P101
miso
P100
cs
P206
EK-RA4W1
SPI0
sck
P102
mosi
P101
miso
P100
cs
P103
EK-RA6M1
SPI0
sck
P102
mosi
P101
miso
P100
cs
P103
EK-RA6M2
SPI0
SPI1
sck
P102
P702
mosi
P101
P701
miso
P100
P700
cs
P103
P703
RA4M1-CLICKER
SPI0
sck
P102
mosi
P101
miso
P100
cs
P103
SPI.init(firstbit)    # now fixed with SPI.LSB
SPI.init(baudrate)    # now confirmed only 500000
I2C bus
i2c.scan()         # returns list of slave addresses
i2c.readfrom_mem(0x50, 0x10, 2, addrsize=16)  # read 2 bytes from slave 0x50, slave memory 0x10
EK-RA4M1
scl
not supported
sda
not supported
EK-RA4W1
I2C0
scl
P204
sda
P407
EK-RA6M1
I2C0
scl
P400
sda
P401
EK-RA6M2
I2C2
scl
P512
sda
P511
RA4M1-CLICKER
I2C1
scl
P205
sda
P206
I2C.init(freq)    # now confirmed only 400000
SDCard
import os, vfs, sdcard
vfs.mount(sd, '/sd')
vfs.umount('/sd')
