Quick reference for the ESP8266¶
The Adafruit Feather HUZZAH board (image attribution: Adafruit).
Below is a quick reference for ESP8266-based boards. If it is your first time working with this board please consider reading the following sections first:
See the corresponding section of tutorial: Getting started with MicroPython on the ESP8266. It also includes a troubleshooting subsection.
machine.freq(160000000) # set the CPU frequency to 160 MHz
The network
wlan.ifconfig() # get the interface's IP/netmask/gw/DNS addresses
to create and use TCP/UDP sockets as usual.
Virtual (RTOS-based) timers are supported. Use the machine.Timer class with timer ID of -1:
Available pins are: 0, 1, 2, 3, 4, 5, 12, 13, 14, 15, 16, which correspond to the actual GPIO pin numbers of ESP8266 chip. Note that many end-user boards use their own adhoc pin numbering (marked e.g. D0, D1, …). As MicroPython supports different boards and modules, physical pin numbering was chosen as the lowest common denominator. For mapping between board logical pins and physical chip pins, consult your board documentation.
Note that Pin(1) and Pin(3) are REPL UART TX and RX respectively.
Also note that Pin(16) is a special pin (used for wakeup from deepsleep
mode) and may be not available for use with higher-level classes like
Neopixel
uart = UART(0, baudrate=9600)
uart.write('hello')
uart.read(5) # read up to 5 bytes
Two UARTs are available. UART0 is on Pins 1 (TX) and 3 (RX). UART0 is bidirectional, and by default is used for the REPL. UART1 is on Pins 2 (TX) and 8 (RX) however Pin 8 is used to connect the flash chip, so UART1 is TX only.
When UART0 is attached to the REPL, all incoming chars on UART(0) go straight to stdin so uart.read() will always return None. Use sys.stdin.read() if it’s needed to read characters from the UART(0) while it’s also used for the REPL (or detach, read, then reattach). When detached the UART(0) can be used for other purposes.
If there are no objects in any of the dupterm slots when the REPL is started (on hard or soft reset) then UART(0) is automatically attached. Without this, the only way to recover a board without a REPL would be to completely erase and reflash (which would install the default boot.py which attaches the REPL).
To detach the REPL from UART0, use:
import os
os.dupterm(None, 1)
The REPL is attached by default. If you have detached it, to reattach it use:
import os, machine
uart = machine.UART(0, 115200)
os.dupterm(uart, 1)
PWM can be enabled on all pins except Pin(16). There is a single frequency for all channels, with range between 1 and 1000 (measured in Hz). The duty cycle is between 0 and 1023 inclusive.
Use the machine.PWM
pwm0 = PWM(Pin(0)) # create PWM object from a pin
pwm0.freq() # get current frequency
pwm0.freq(1000) # set frequency
pwm0.duty() # get current duty cycle
pwm0.duty(200) # set duty cycle
pwm2 = PWM(Pin(2), freq=500, duty=512) # create and configure in one go
ADC is available on a dedicated pin. Note that input voltages on the ADC pin must be between 0v and 1.0v.
adc = ADC(0) # create ADC object on ADC pin
adc.read() # read value, 0-1024
There are two SPI drivers. One is implemented in software (bit-banging) and works on all pins, and is accessed via the machine.SoftSPI class:
# construct an SPI bus on the given pins
The hardware SPI is faster (up to 80Mhz), but only works on following pins:
MISO
is GPIO12, MOSI
is GPIO13, and SCK
is GPIO14. It has the same
methods as the bitbanging SPI class above, except for the pin parameters for the
constructor and init (as those are fixed):
hspi = SPI(1, baudrate=80000000, polarity=0, phase=0)
(SPI(0)
is used for FlashROM and not available to users.)
The I2C driver is implemented in software and works on all pins, and is accessed via the machine.I2C class (which is an alias of machine.SoftI2C):
# construct an I2C bus
i2c = I2C(scl=Pin(5), sda=Pin(4), freq=100000)
i2c.readfrom(0x3a, 4) # read 4 bytes from peripheral device with address 0x3a
i2c.writeto(0x3a, '12') # write '12' to peripheral device with address 0x3a
# synchronize with ntp
# need to be connected to wifi
import ntptime
ntptime.settime() # set the rtc datetime from the remote server
rtc.datetime() # get the date and time in UTC
Not all methods are implemented: RTC.now()
, RTC.irq(handler=*)
(using a custom handler), RTC.init()
and RTC.deinit()
are
currently not supported.
# enable the WDT
wdt = WDT()
Connect GPIO16 to the reset pin (RST on HUZZAH). Then the following code can be used to sleep, wake and check the reset cause:
# configure RTC.ALARM0 to be able to wake the device
rtc = machine.RTC()
rtc.irq(trigger=rtc.ALARM0, wake=machine.DEEPSLEEP)
# set RTC.ALARM0 to fire after 10 seconds (waking the device)
rtc.alarm(rtc.ALARM0, 10000)
# put the device to sleep
NeoPixel driver¶
APA102 driver¶
Use the apa102
from apa102 import APA102
clock = Pin(14, Pin.OUT) # set GPIO14 to output to drive the clock
data = Pin(13, Pin.OUT) # set GPIO13 to output to drive the data
apa = APA102(clock, data, 8) # create APA102 driver on the clock and the data pin for 8 pixels
apa[0] = (255, 255, 255, 31) # set the first pixel to white with a maximum brightness of 31
apa.write() # write data to all pixels
r, g, b, brightness = apa[0] # get first pixel colour
For low-level driving of an APA102:
esp.apa102_write(clock_pin, data_pin, rgbi_buf)
SSD1306 driver¶
Driver for SSD1306 monochrome OLED displays. See tutorial Using a SSD1306 OLED display.
import ssd1306
display = ssd1306.SSD1306_I2C(128, 64, i2c)
display.text('Hello World', 0, 0, 1)
display.show()
WebREPL (REPL over WebSockets, accessible via a web browser) is an experimental feature available in ESP8266 port. Download web client from https://github.com/micropython/webrepl (hosted version available at http://micropython.org/webrepl), and configure it by executing:
The supported way to use WebREPL is by connecting to ESP8266 access point, but the daemon is also started on STA interface if it is active, so if your router is set up and works correctly, you may also use WebREPL while connected to your normal Internet access point (use the ESP8266 AP connection method if you face any issues).
Besides terminal/command prompt access, WebREPL also has provision for file
transfer (both upload and download). Web client has buttons for the
corresponding functions, or you can use command-line client webrepl_cli.py
See the MicroPython forum for other community-supported alternatives to transfer files to ESP8266.
