This is the v1.20.0 version of the MicroPython documentation. The latest development version of this page may be more current.
4. Network basics
The network module is used to configure the WiFi connection. There are two WiFi interfaces, one for the station (when the ESP8266 connects to a router) and one for the access point (for other devices to connect to the ESP8266). Create instances of these objects using:
>>> import network
>>> sta_if = network.WLAN(network.STA_IF)
>>> ap_if = network.WLAN(network.AP_IF)
You can check if the interfaces are active by:
>>> sta_if.active()
False
>>> ap_if.active()
True
You can also check the network settings of the interface by:
>>> ap_if.ifconfig()
('192.168.4.1', '255.255.255.0', '192.168.4.1', '8.8.8.8')
The returned values are: IP address, netmask, gateway, DNS.
4.1. Configuration of the WiFi
Upon a fresh install the ESP8266 is configured in access point mode, so the AP_IF interface is active and the STA_IF interface is inactive. You can configure the module to connect to your own network using the STA_IF interface.
First activate the station interface:
>>> sta_if.active(True)
Then connect to your WiFi network:
>>> sta_if.connect('<your SSID>', '<your key>')
To check if the connection is established use:
>>> sta_if.isconnected()
Once established you can check the IP address:
>>> sta_if.ifconfig()
('192.168.0.2', '255.255.255.0', '192.168.0.1', '8.8.8.8')
You can then disable the access-point interface if you no longer need it:
>>> ap_if.active(False)
Here is a function you can run (or put in your boot.py file) to automatically connect to your WiFi network:
    if not sta_if.isconnected():
        sta_if.active(True)
        sta_if.connect('<ssid>', '<key>')
        while not sta_if.isconnected():
    print('network config:', sta_if.ifconfig())
4.2. Sockets
Once the WiFi is set up the way to access the network is by using sockets. A socket represents an endpoint on a network device, and when two sockets are connected together communication can proceed. Internet protocols are built on top of sockets, such as email (SMTP), the web (HTTP), telnet, ssh, among many others. Each of these protocols is assigned a specific port, which is just an integer. Given an IP address and a port number you can connect to a remote device and start talking with it.
The next part of the tutorial discusses how to use sockets to do some common and useful network tasks.
