Memory Management¶
Unlike programming languages such as C/C++, MicroPython hides memory management details from the developer by supporting automatic memory management. Automatic memory management is a technique used by operating systems or applications to automatically manage the allocation and deallocation of memory. This eliminates challenges such as forgetting to free the memory allocated to an object. Automatic memory management also avoids the critical issue of using memory that is already released. Automatic memory management takes many forms, one of them being garbage collection (GC).
The garbage collector usually has two responsibilities;
Allocate new objects in available memory.
Free unused memory.
There are many GC algorithms but MicroPython uses the Mark and Sweep policy for managing memory. This algorithm has a mark phase that traverses the heap marking all live objects while the sweep phase goes through the heap reclaiming all unmarked objects.
Garbage collection functionality in MicroPython is available through the gc
built-in
>>> x = 5
>>> x
>>> import gc
>>> gc.enable()
>>> gc.mem_alloc()
1312
>>> gc.mem_free()
2071392
>>> gc.collect()
19
>>> gc.disable()
Even when gc.disable()
is invoked, collection can be triggered with gc.collect()
The object model¶
All MicroPython objects are referred to by the mp_obj_t
data type.
This is usually word-sized (i.e. the same size as a pointer on the target architecture),
and can be typically 32-bit (STM32, nRF, ESP32, Unix x86) or 64-bit (Unix x64).
It can also be greater than a word-size for certain object representations, for
example OBJ_REPR_D
has a 64-bit sized mp_obj_t
on a 32-bit architecture.
An mp_obj_t
represents a MicroPython object, for example an integer, float, type, dict or
class instance. Some objects, like booleans and small integers, have their value stored directly
in the mp_obj_t
value and do not require additional memory. Other objects have their value
store elsewhere in memory (for example on the garbage-collected heap) and their mp_obj_t
contains
a pointer to that memory. A portion of mp_obj_t
is the tag which tells what type of object it is.
See py/mpconfig.h
for the specific details of the available representations.
Pointer tagging
Because pointers are word-aligned, when they are stored in an mp_obj_t
the
lower bits of this object handle will be zero. For example on a 32-bit architecture
the lower 2 bits will be zero:
********|********|********|******00
These bits are reserved for purposes of storing a tag. The tag stores extra information as opposed to introducing a new field to store that information in the object, which may be inefficient. In MicroPython the tag tells if we are dealing with a small integer, interned (small) string or a concrete object, and different semantics apply to each of these.
For small integers the mapping is this:
********|********|********|*******1
Where the asterisks hold the actual integer value. For an interned string or an immediate
object (e.g. True
) the layout of the mp_obj_t
value is, respectively:
********|********|********|*****010
********|********|********|*****110
While a concrete object that is none of the above takes the form:
The stars here correspond to the address of the concrete object in memory.
Allocation of objects¶
The value of a small integer is stored directly in the mp_obj_t
and will be
allocated in-place, not on the heap or elsewhere. As such, creation of small
integers does not affect the heap. Similarly for interned strings that already have
their textual data stored elsewhere, and immediate values like None
, False
and True
Everything else which is a concrete object is allocated on the heap and its object structure is such that a field is reserved in the object header to store the type of the object.
+ type + object header
+ + object items
The heap’s smallest unit of allocation is a block, which is four machine words in size (16 bytes on a 32-bit machine, 32 bytes on a 64-bit machine). Another structure also allocated on the heap tracks the allocation of objects in each block. This structure is called a bitmap.
The bitmap tracks whether a block is “free” or “in use” and use two bits to track this state for each block.
The mark-sweep garbage collector manages the objects allocated on the heap, and also utilises the bitmap to mark objects that are still in use. See py/gc.c for the full implementation of these details.
Allocation: heap layout
The heap is arranged such that it consists of blocks in pools. A block can have different properties:
ATB(allocation table byte): If set, then the block is a normal block
FREE: Free block
HEAD: Head of a chain of blocks
TAIL: In the tail of a chain of blocks
MARK : Marked head block
FTB(finaliser table byte): If set, then the block has a finaliser
