Quick reference for the Renesas RA¶
![Renesas Evaluation Kit for RA6M2 MCU Group](../_images/ek_ra6m2_board.jpg)
Use the machine.Timer
- Following functions are not supported at the present::
p0 = Pin('P000', Pin.OUT) # create output pin on P000
p4 = Pin('P004', Pin.PULL_UP) # enable internal pull-up register
EK-RA4M1 |
UART0(REPL) |
P411 |
P401 |
P302 |
P410 |
P402 |
P301 |
EK-RA4W1 |
UART4(REPL) |
UART9 |
P213 |
P204 |
P109 |
P212 |
P206 |
P110 |
EK-RA6M1 |
UART0(REPL) |
UART8 |
P411 |
P302 |
P105 |
P410 |
P301 |
P104 |
EK-RA6M2 |
UART0(REPL) |
UART7 |
UART9 |
P411 |
P401 |
P602 |
P410 |
P402 |
P601 |
RA4M1-CLICKER |
UART1(REPL) |
P411 |
P401 |
P410 |
P402 |
UART.init(baudrate) # now only 115200 is confirmed
UART.init(cts, rts) # Pins are fixed.
UART.init(tx,rx) # Pins are fixed.
# time, eg 2017/8/23 1:12:48
adc = ADC('P000') # create an ADC object acting on a pin
adc.read_u16() # read a raw analog value in the range 0-65535
SPI bus¶
EK-RA4M1 |
SPI0 |
P102 |
P101 |
P100 |
cs |
P206 |
EK-RA4W1 |
SPI0 |
P102 |
P101 |
P100 |
cs |
P103 |
EK-RA6M1 |
SPI0 |
P102 |
P101 |
P100 |
cs |
P103 |
EK-RA6M2 |
SPI0 |
SPI1 |
P102 |
P702 |
P101 |
P701 |
P100 |
P700 |
cs |
P103 |
P703 |
RA4M1-CLICKER |
SPI0 |
P102 |
P101 |
P100 |
cs |
P103 |
SPI.init(firstbit) # now fixed with SPI.LSB
SPI.init(baudrate) # now confirmed only 500000
i2c.scan() # returns list of slave addresses
i2c.readfrom_mem(0x50, 0x10, 2, addrsize=16) # read 2 bytes from slave 0x50, slave memory 0x10
EK-RA4M1 |
not supported |
not supported |
EK-RA4W1 |
I2C0 |
P204 |
P407 |
EK-RA6M1 |
I2C0 |
P400 |
P401 |
EK-RA6M2 |
I2C2 |
P512 |
P511 |
RA4M1-CLICKER |
I2C1 |
P205 |
P206 |
I2C.init(freq) # now confirmed only 400000
SDCard¶
import os, sdcard
os.mount(sd, '/sd')
os.umount('/sd')
